Almost have one aluminum piston so far: everything is just about perfect except the wall got very thin at the large opening at the bottom of the skirt. The wall here is probably about half as thick as it should be as per the drawings. Not sure if it’s usable or not, there are a lot of steps to machining just one piston. This is my third one too. I made a couple of dumb mistakes on the others. I found that the 0.625 root diameter on the crown of the piston is a critical measurement. Otherwise it doesn’t fit right into the slave fixture and the gungean hole will be off… Also, again, I’m having trouble with the thin wall at the opening of the piston. My first one was perfect, but I screwed something else up, I’m using a 11/16” End Mill four flute cutter here rather than a boring tool…
