Personally I think it’s better to lap all the bores 'the same' & whatever that dimension happens to be is how you make the pistons & particularly the rings to suite. You will have all the messy lapping apparatus set up, so just circulate the cylinders on the same lap tool setting, rinse & repeat. Actually even this isn't 100% precise because the lap will wear a bit from cyl-1 to cyl-9, so alter the order or keep track of the finishing lap, but hopefully you get my point. After break in for sure keep the rings mated to their cylinders, but making a custom ring per cylinder sounds like a lot of unnecessary work to me.
