idahoan
- Oct 7, 2008
- 594
- 210
She's looking good Bill;
With regards to heat requirement; are you planning on making a steel hot end with a copper cap? I'm not sure what your prints call out but when my buddy built his Denney Improved engine the plans called out an all copper hot end (bad idea). It transferred so much heat into the cold end that it wouldn't run well. It was hard to keep the water cool and a huge flame was required just to keep it running.
When he built his Rider Ericsson last winter he made a steel hot end with a thin copper hot cap; man what a difference that made. He also turned a waist near the top (ala Jerry Howell) to help stop the heat migration from the hot end to the cold end.
After the Rider was finished he went back and made a new hot end for the Denney and now it runs just as well or maybe better than the Rider.
Some food for thought; one other item is that he has trouble with, is the pump check ball sticking when it dries out. Last weekend at the show we had to remove the nut and plunger to get it freed up with a long skinny screwdriver. Maybe it is our fine Boise Idaho water; not sure but I would bet a Teflon ball wouldn't stick.
Looking forward to the video of it running.
