glue-itcom
- Apr 10, 2013
- 216
- 301
This boiler has now finally been rebuilt with better cladding and a new firebox. This time the firebox has been made from sheet mild steel.
Hi Pete, sorry, just a piston pump. I think a proper injector would be very difficult without lots of cfd and then lots of testing. Cheers, NigelYou mention in the video making an injector to deliver water to the boiler.
Are you proposing a real injector at this scale, or a piston pump?
I'll be very impressed if you can get an injector to work!
Thanks for the tip on using a pencil mark, I've never seen that before. I'm used to mixing the flux with water, works very well.Good to see different techniques - and that they work! Hope the silver soldering to the boiler goes well. A tip? Try using a pencil to mark off the area beyond the joint where you don't want the silver solder to take. Just "shade" the area, but make sure no pencil where you do want the solder. Also using a paste of flux and water pre-applied ensures it fills the gap to clean the surfaces and encourage the capilliary action when silver solder is applied. (But I reckon you know all that anyway.).
Hope the pencil mark helps? I forget to bother... so have widespread silver solder coating everywhere.
K2.
