After installing a collet closer attachment to my Grizzly G4002 lathe, I checked the stock with an indicator, as theoretically speaking, stock held in a collet should run relatively true. The stock was found to be running out by 0.002. So I took the nose cone out of the taper and ran an indicator on that and found that the spindle itself was running out 0.002. Is there a fix for this? Or is it, as I suspect, insignificant enough as to not warrant any action at all.
