Try this price for a mini lathe
SmithDoor
Staff member
Global Moderator
Clovis Ca
The see shipping
Hight lite between brackets for price { $396 }
Always check price of shipping.
https://www.aliexpress.us/item/3256808012782050.html?ug_edm_item_id=3256808012782050&pdp_npi=4@dis!USD!$245.88!$245.88!!!!!@2151e4c417399382639126803ddcbd!12000044210907756!edm!!!&edm_click_module=alg_product_l1r2_5971640600&creative_img_ind=1&edm_log_data=edm-item-list-left-one-right-two.store-product-log-link&tracelog=rowan&rowan_id1=aeug_edm_23832_1_en_US_2025-02-18&rowan_msg_id=gunsCOWS_23832_$fedd6ca5579f42b782aac414f45a181a&ck=in_edm_other&gatewayAdapt=glo2usa
The link you post is for the table.
There are different pictures where you select the "colour" of the item.
This is how you select what item you want, like different sizes or types of cutters as an example.
The Lathe itself is more like 1k.
Aliexpress isn't for making a snap decision. You get what you bought, not what you thought you bought. You need to look at all the pictures, compare the prices based on the picture highlighted, then read the description, then add in the shipping cost. While the lathe can be had (one of them, make sure you know which one)for the low price of $880, you then need to add in the shipping (about $400). Then you need to factor in the chance of shipping damage and what it might take to repair it. By the time you are done, you might have been better off to have bought a mini lathe from Harbor Freight.
Asking questions is a way to clarify details and get some idea if the seller knows what he is doing. It shows if they are able to communicate.
Sometimes extra photos are possible. I had succes in requesting e.g. wiring information before ordering. (often all the information is only about shipping workflow, shipping times and packaging) Technical information is sometimes sparse. Choices are "walk away", "ask" or "gamble".
p.s. mixed results, quite some stories with wrong or not compatible items. Usually not scams, but mixed specs. (by me or shipper).
Buy cheap buy twice, order wrong order twice.
I new a guy that purchased from Asia. He would buy 10 drill press, bench mills and other tools. He said very thing he purchased had to fit in a box 4x4x5 for best price on shipping. I think it was $150 in 1970’s port side.
Later he also did lathes too limit to size of next size crate greater cost.
The lathes , mills and drill press is low cost but by you add in shipping to post then to your location it climes.
The last did a container 60 foot long to south America using Panama Canal it cost $6,000 port to port in 2001. From my shop to port add $600.00
