Rob,
Start out by making a tool like the one attached. Lightly cut the seat. This tool will ensure that the seat is concentric with the guide hole. After that put a little lapping compound on the valve and insert it into the head. Attach a small drill chuck or pin vise to the valve stem. Rotate the valve back and forth while every couple of cycles lift it off of the seat to redistribute the lapping compound. It shouldn't take much to lap it in. To test I make up a bushing adapter for my vacuum gauge. The one end will have a diameter a thousand or two larger than the port diameter. Then file a tiny taper on it. You can wring this into the port and attach the vacuum gauge or just a piece of tube and suck on it. Make sure you put a drop of oil on the valve guide to seal it while checking.
  • VALVE SEAT CUTTER INSTRUCTIONS.pdf
    23.1 KB
Been chasing the runout in the lathe chuck for the machining of the valve seat. Replaced the 3 jaw chuck and fitted the ER32 collet and now have a runout of 0.01mm. The 3jaw was 0.08mm runout.
Had to get a wide mouth wrench for the chuck as really needed to tighten down the collets to align properly. The flats on the chuck were 36mm so had nothing that big.
    179.1 KB
    1.8 MB
For whatever reason my seat cutter lost its cutting edge after 4 seats. Assume I didnt heat treat properly. I did struggle to grind the relief on the back of the edge. In saying that the two valves I lapped in did hold pressure OK. I had thought I could of machined the relief on the mill but the compound angle did my head-in how to set it up. I had thought I would simple turn the cutter 15 deg in the collet then clamp the collet at 45 deg but didnt realise I need to turn the vice on another angle of ??. So did my best on the 6" grinder by hand. I did learn 1. how hard it is to remove ALL lapping paste -had to get some brake cleaner and 2. went too hard on the first valve and the 600 grit took too much from the SS valve. So had to skim that valve and do it again softly. Have ordered some 1200 grit silica carbide as thinking 600 was a little too course to finish off with.
    176.8 KB
    242.1 KB
    100.3 KB
Last valve lapped and pressure tested…. Thanks for the plans for the cutter @gbritnell
Think the valves tested ok (video of the last vlv tested linked below) although my second head was better as the seats were smaller…. In hindsight my cutter may of been too sharp on the 1st head and took a little too much off, as when I thought it was getting blunt it probably did a better job on the second head in just taking a very small surface cut. Took 15 minutes of lapping each vlv to get this result.
Now the valves are installed, the dam valve spring retainer hits on the edge of the rocker arm before it hits the top of the valve stem. I think if i bevel the edge of the spring retainer that might be enough. Or i file under the rocker arm. Its probably 0.5mm need removing from somewhere.
Next is. the inlet manifold and carby.
    2 MB
Had some time for the check valve. The 3/8-32 die I purchased had a long leed in on both sides of the die. so made a small threaded insert and Ill glue it into the cap with some loctite. Dont know how to get a nice dome on the cap so I will just machine a square top with a 45 degree bevel edge
    1.8 MB
Well the long weekend is over and I managed to find time to complete the PCV valve and nearly completed the air filter assembly.
Next on the list is to complete the carby throttle shaft, needle valve and a fuel tank. so at least the fuel system into the cylinders including the valves is a nice milestone before easter.
    1.6 MB
Well now I zoom up on my needle valve I see I may of squished the threaded stainless steel rod very slightly with the 3jaw chuck, but Im happy that I could achieve the tolerances in the plan. I purchased this 240VAC Dremel from aliexpress for like AUD$50.00, 4 years ago and made a simple tool post holder. I liked it as it had a cast collar I can clamp to. I suppose I should of got a better grinding wheel and used the cross slide for the angle but this wheel did the job with a little trial and error..
    207.8 KB
    190.2 KB
I have also been seeing how best I can get some radiator hoses and hose clamps. The black silicon tube I purchased is OK but found I could slip over some woven sleeving making it look a little more realistic than the shiny black silicon tube I purchased. I have purchased a few meters of different colour sleeving and will see which suits the best but I think a straight black or blue hose is what I am hoping for in the end and I found some small wire type hose clamps for both the larger and smaller water hoses as I plan out how best I can complete the cooling system, which is next after I complete the carby and fuel tank !
    249.2 KB
