For a project, I've had 1,243 stainless steel discs between 13-51mm laser cut out of 0.5mm thick sheet.
They are held in the sheet by a small tag approx. 0.5mm wide and each disc is then twisted out of the sheet.
The separated discs have a tiny tag "stump" to one edge which I've been hand filing off in prototype stage (maybe 22 discs for one instrument) but for this larger quantity I need to remove the stumps more quickly.
What would be best... a bench grinder or a bench belt sander? I could buy a small machine which has both but I may be going down the wrong pat with either!
What would you suggest? If you have a type of machine in mind please post a link. Many thanks.
Something like this?...
