Those couplers should have an rpm/temp rating for the spiders iirc. Unless they are random internet ones
@nerd100 probably has the right idea then, going all metal.The couplers were purchased via AliExpress :Plum Coupler
The only specs given are diameter, length, and shaft size,....and the spider is Polyurethane.
Wait a minute, wait a minute. .83 LPM? you must mean .083 LPM? at .83 you would have a veritable explosion. You'd need a huge boiler.Steam flow rate was 0.83 LPM (Liters Per Minute) at just over 100 C and at nearly zero pressure. The coupler melted before I had a chance to measure RPMs and the voltage reading was made after RPMs had already dropped off. This test ended too quickly to have provided adequate data.
I THINK the coupler melted from heat created by friction as the stainless steel TT drive shaft spun inside the aluminum coupler, after the steam heat loosened the connection. I don't believe the steam heat alone melted the coupler's plastic spider. I'll tighten the coupler onto the shaft a bit tighter for the next test,...hopefully, that will be enough.
Both TT bearings are full ceramic which run "dry" (no grease or oil).
I still haven't been able to set the temp and pressure sensors to display accurate readings; view them as +/- 30.Hi, Can you explain Boiler temp out at "91", and 31psi? - sounds like hot water, not steam. If inlet pressure is 35psi, and outlet 31psi, then the inlet pump is providing the pressure, not the burner "adding enthalpy"(or something...??) if my thermodynamics is right? - SO I am not sure what this is telling me. (I stopped video at 15 seconds run-time).
Thanks,
Probably a working temp around 75°c according to some generalized data sheets.The couplers were purchased via AliExpress :Plum Coupler
Thanks, I understand!
Do you have a mechanical pressure gauge you can affix? - may be within a few %...
And maybe rest some soft solder on the pipe - when it reaches melt temperature you have a control standard for resetting your fancy digital thing?
You can use some RC filters to get rid of the noise.I have the liquid filled dial guage shown in the video in post #305 at 11 sec in, and I have been using that guage as my "gold standard" for pressure values, for adjusting pressure sensor values. But the real problems are electrical noise generated by the 3 motors, the two DC to DC power supplies I use to drop the 36 vdc down to 12 vdc and 5 vdc, and the very small voltages from the sensors which represent pressure and temperature.
The Arduino micro computer I'm using as the ECU (Engine Control Unit) can only use 0 to 5 volts dc to read the full pressure range of 0 to 500 psi. The range on the pressure sensors is 0 to 1000 psi, meaning their 5 volt output indicates a 1000 psi pressure, a 2.5 volt reading represents 500 psi, and 0.5 volt reading represents 100 psi.
The 35 & 31 psi readings seen on the display during the test run meant the two pressure sensors were sending out 0.175 and 0.155 volts respectively. Reading those small values accurately when the electrical noise level is 0.200 to 0.300 volts is challenging at best, and impossible at worst.
Well done for trying, but looking at the voltage values for your instrumentation it does seem to me to be " impossible at worst." But are these pressure values used in the controls, or just for interest? If control parameters, then you need to invest in some more suitable sensors... but for now I suspect you are just tickling the tiger's tail, not really trying to push for 500psi steam! So maybe when to develop more pressure and reduce noise things will start to work sensibly?
GOOD LUCK!
Dealing with the noise from the PSU is a good start.I've already tried hanging 1000uf caps and various resistor values onto the power supply outputs with very little success. I've just ordered some LC filters made for power supply noise suppression,...hopefully these will work
I'd suggest also putting filters between your Arduino pins and their respective sensors. An RC low pass filter is what you want, this will help remove high frequency electrical noise from the signals.
Also with your motors did you put a capacitor in parallel with the motor? It's such a common method to suppress noise from brushes that even cheap toys use it. Motors that only run one way can also have a flyback diode to improve matters further.
One other thought: what's the situation with your signal wires? As you probably know they can act as antennas for radio frequency noise, which could be coming from the brushes of your motors I suppose.All good ideas.
I've had limited success using RC filters on the sensor input, but this is an area I need to revisit as the tests I performed were all done when I was still using the bad wires from China. Now that I've hopefully found and replaced all the faulty wires, I need to insert various RC values while watching the sensor signals on my O-scope.
Adding caps and diodes to the motors was the first step I took ,...I even added MOVs to the blower motor.
Makes me glad of brushless motors, no noisy commutator!
