I had that incorrect valve timing figured out when I seen bubbles around the throttle cross shaft.--But if its leaking air out the carb under compression stroke, then it is also leaking air there during an intake stroke. I like this carb because It's so simple, but I also don't really trust it because it's so simple. I have made up a different intake manifold that will accept one of my tried and true Traxxas carbs. I just got word today from the surgeon that they are going to replace my other knee on the 14th of November.
