peterl95124
- Feb 22, 2020
- 500
- 322
this 2/3 scale Muncaster #9 Joy's Valve Engine is all built from bar stock,
except the base, its "cast" from TIG !!!
my original inspiration was Simon Fraser's 2/3 scale, but in hind sight probably should have done raveney's 1/2 scale. my base is 5 x 14+"
and the reason I found Simon's work is I was looking for Joy's Valve Gear info because that's what's in the Van Vleck designed, Dickson built, Triple Expansion Steam Engine, with Edison Dynamos at the "thehenryford.org" museum, which I'd also like to model some day.
raw "casting",
critical dimensions machined,
and cosmetics machined, 2-deg draft angle all around and rounded corners
raw "casting",
