Lohring--Thank you for an incredible piece of work.---Brian
As promised, I quickly (for me) drew up a modified version of the Wombat. I did not draw a carb or ignition system, just the internal parts. You can use the Wombat systems or a Walboro WT-157-1 and a CD ignition. I included a simple block crankcase as well as a more Wombat like version. Plates that I didn't draw cover the transfer passages in the block. I think this is about as simple as a two stroke gets, but I assumed some engine building experience. If anyone actually wants to build one, I would be glad to go into more detail. The drawings haven't been checked so they probably contain errors. I would draw an assembly as the minimum check.
Lohring Miller
eyeballing the pic, guessing 7/16 should be 'diameter'
I know that but read the plans and they don't matchI believe the circles with the lines thru them are a drafting convention meaning "Diameter".
At least that's how I have read them.
Ron
JasonLuc wall thickness will be 3/32" not 3/16"
Jason
.438-.250=.188/.0625=3 and that would be 3/16
or what did I do wrong
