- Jul 8, 2009
- 688
- 201
ajoeiam:
My shop has NEVER been this organized before, I MIGHT take a picture tonight of what most of the horizontal surfaces in the shop looked like before this little escapade began.
The heating system won't get anything done to it, that it doesn't need to keep running, until April or May when it finally shuts down. I had to replace the boiler controller a month or so ago, it wasn't firing the boiler long enough to get the loop temperaturre over about 105-110°F. Since then I have had the bad controller repaired and it's on the shelf waiting to be called back into service, along with enough spare parts to almost build a spare boiler. I learned my lesson a couple of years ago when a sensor went bad on the boiler and no local suppliers had the parts for it, I ordered a boat-load of spares on-line.
I didn't get too much done in the shop last night. I installed the 3D printed hose adapter for the tablesaw's dust collector connection - no more Redneck Engineering rag stuffed in around the hose to seal the air leak. I'm not sure if re-use that 3D printed adapter in the final connection to the tablesaw or not. The connection to the existing dust port on the saw is a 2.25" shop vac hose. I'd like to build a dust pick-up for the top of the blade, to use when making through cuts. I'll use a 3" hose to the saw and then split that 3" connection between the existing dust port and the connection to the top of the blade. That way I'm not starving either port for air.
I also replaced most of the overly long 6-32 screws, that were bolting the tops and bottoms of the slide gates together, with screws of the correct length. The correct length screws were part of the Monster Bolts order that I just got. Since I moved the radial arm saw I just can't get my hand between the saw's column, the 4" dust collector duct, and the wall enough to get at last the screw. I'll have to move the saw to get to that bolt, but this should be the last time that bolt needs to be touched.
Don
Don
