- Jul 8, 2009
- 688
- 201
About 20-25 years ago I made a pair of Shop Notes dust collector cyclones. I used an electric leaf blower for the DC fan. My calculations showed it was moving about 300-350 CFM. I made a prototype cylcone for my shop to see if it worked. I used the air filter from an '89 Aerostar as the final filter, calculations showed that it was capable of 350 CFM plus.. It was a noisy DC but it worked surprisingly well. I then made a nicer version that I gave to my Dad for his shop as a Christmas present. When my Mom and Dad moved off their acreage into a condo in 2007, for health reasons, he gave the DC back to me since he'd never be able to use it again.
A house move later and I getting the DC cyclone set up in my shop again. I decided to improve it a little this time, I'm upgrading from the noisy leaf blower to a slightly quiter 600 CFM dust collector blower, and I'm adding an airlock to the cyclone discharge - airlocks are also sometimes called rotary valves. Before we had to seal the discharge bin and that made it a PITA to check the level in the bin - or to empty the bin.
Since I've got a 3D printer now I decided I could print some of the airlock parts and get a lot neater airlock than anything I could cobble together otherwise. The airlock body is a piece of 3" schedule 80 PVC pipe that's 150mm long. The drive motor for the airlock is a 20RPM 12VDC gearmotor, I just happen to have a 12V wall wart that will work nicely for a power supply. I'll wire in a switched outlet that will power both the fan and the wall wart and run the airlock whenever the fan is running.
Here's an in progress picture of the print of the part I'm calling the adapter. The adapter is the transition piece that goes from the 6" round DC cyclone discharge to the rectangular-ish opening on the airlock body. It was about 7 hours into the print when this picture was taken. The entire print was estimated to take 18 hours, I started it at night when I went to bed and it was complete when I came home from work the next day. I'm guessing the print time was in the 18-19 hour range since the bed was still warm when I got home.
The priming strip on the left is 2mm from the Y axis of the printer so the print is pushing the print envelope of the printer.
I've got most of the parts printed, and I'm working on cutting the inlet and discharge openings in the body of the airlock. If anybody's interested I can take some more pictures and show you what I've got done so far.
Don
Don
