ShedBoy
Senior Member
- May 13, 2011
- 792
- 34
Got some more parts made and mounted.
Some point to mount the rear master cylinder, changing from drum to disc just requires some small tubes welded to the frame, using original style MC.
Brake light switch.
Electric dash is mounted.
The beginnings of a battery box, wanted to keep it very clean under the seat, needs some trimming.
Battery in the box, dry cell type so it will work anyway except upside down, just need to fit a fuse box, starter relay, flasher unit etc in there with it. Not many little parts to go now before pull it apart to get painted, powder coated and plated. Also had to take some time out to put some paint on the better half's project (which I seem to do most the work on), it is a esky (to an aussie), chilly bin (to a kiwi) or cooler (to an American). It started life as a round top fridge.
Still needs some more detail put on it. Can you guess what it is meant to be
yet?
Really miss machining something, I bring it on myself.
Thanks for looking in
Brock
Brake light switch.
yet?
Brock
