- May 3, 2011
- 415
- 68
forgot.......
are you making the NGV or getting a cast one?
Have you by any chance still have the turbo prop second stage build plans? Because as you might know wrenn website is no longer available.Hello,
I was wondering if anyone out there has built the MW54 MK1 turbine from Wren. I got these plans available for free from Wrens website. It he only tool I don't have is a milling machine, which would make the machining of the diffuser a lot easier. This is my first jet engine I have tried to create. I'd appreciate any ideas or experiences with this build that you might have.
http://www.wrenturbinesusa.net/mw54-turbo-jet-and-turbo-prop-second-stage-plans
Hi CEB2,Have you by any chance still have the turbo prop second stage build plans? Because as you might know wrenn website is no longer available.
Thanks a lot, those two ressources links are so complete.This post got my interest and I found this site. Does it look right and complete?
http://www.totallyscrewedmachineshop.com/documents/documents.html
Nothing wrong with your test stand! I want to build a small test stand for my engine, which I hope to do this fall. I wanted to make my own ECU and have it all as one unit. Nothing fancy, just to run my engine.Like your test stand, a bit better than my one.
What's with the colour of the diffuser? Have you coated it with something?
Will be a problem with building another 54. You can still get the compressor, NGV could be CNC from SS, but the turbine wheel is the problem.
You could machine one out from inconel or there is always JET Joe????
Oh interesting. I did not realize that.JetJoè sells by mail order I bought 2 fuel pumps.
how did you make the fuel pump?
Not seen the beer-cooler, but have seen several leaf blowers. Can't wait for the hair dryer.
i think the problem with any build now is the turbine wheel. i haven't looked into building a turbine for a few years and where you can get the bits and bobs from.
i think the bigger turbines are the way to go, as the lower RPM wheels can be machined from SS or inconel.
Again not been on the GTBA website for many years so not to sure what they're doing for turbine wheels.
