Keith Parsloe
New Member
- Jun 8, 2023
- 2
- 0
Are worm gear ratios calculated the same as spur gears ie: 20/40 teeth = 2 to 1 ratio ?.
It means :The ratios are calculated by the number of 'starts' on the worm and the number of teeth on the wormwheel.
Yes, actually what I am thinking is. A worm appears to be "just another" helical gear, because my computer behaves like it. If I enter 1 tooth and 84° helix angle I get this.These are two types of gear being discussed. Worm and wormwheel and crossed helical. Both of which are used on 90 degree shafts. Although Timo may well be correct in assuming the OP meant crossed helical as this is an engine forum, he did ask about worms.
Some general info here on the two types. Differences Between Worm and Helical Gear - Premium Transmission.
I am curious:If anyone is interested, i have Step files for a worm and matching 60t gear. I ducked out of cutting them for a dividing head for my Hobbymat.
Looks like pockets for "nuts", did you try to 3d print it?Hi Timo,
A friend did them for me. He used Fusion 360 and bought in a special add on. Id originally asked him for just the worm but he found it easier to do the two. The gear is 60mm in dia.
I think we are basically on the same page, concerning the naming. Some clever person(s) made software, same rules and formulas seem to work out to make both types of objects.While it's true that worms and helical share a similarity in that that the tooth profile is wound around the axial shaft that's where the similarity ends. A helical gear has it's teeth angled from the axis of the shaft while a worm has it's teeth angled from an angle which is at right angles to the axis. Yes you could say that the angle could be the compliment of the axis angle but in looking at them they present a totally different picture.
A pair of helical gears can run parallel to each other or at right angles to each other (or at some weird angle if needed) whereas a worm and gear set will only operate at right angles to each other.
A worm is calculated by the dimensional advance of a tooth making 1 revolution. This dimension is then used to calculate the amount of rotation of the worm wheel by it's number of teeth. A worm of a given D.P. will operate a worm wheel/gear of any number of teeth as long as the D.P. is the same
What was the declination angle in pic 2453?When building the model of the Galion road grader I had to make all the gears for it because they were all odd sizes. This necessitated making all the cutters. The 2 gear boxes for elevating the blade required worms and wheels. I started with my size requirements and drew a gear that would fit inside the gear box. I then calculated the number of teeth that would fit onto that gear. With that as a starting point I calculated the pitch of the gear and used that to match up to the available threads I could cut with my lathe. I had to keep adjusting the numbers until I could cut the right pitch screw on the lathe. The O.D. of the worm wasn't critical but the pitch was. So now I had the specs for the gear and the pitch of the worm. I adjusted the worm diameter until it matched the center distance needed keeping in mind that the O.D. of the worm couldn't get too large because it had to fit into the depth of the gear box cavity.
I made a cutter the diameter and pitch of the worm. I mounted my gear into my dividing head and tilted it to match the lead angle of the thread I was using. I then cut the gear teeth. A special lathe tool had to be ground to match the pitch of the gear for cutting the worm. It required a large clearance angle on the front face to clear the tooth while threading.
The pictures show the cutter, the setup with the dividing head tilted, the finished gears and worms.
I forgot to mention that 2 sets of worms and gears were required because one was left hand and the other right hand.
