Hi there,
Now and then I read about some Windows 'problems'.
I'm not going to start a pro-con discussion here whether a Win, Linux or Apple OS is better or best.
Thing is, make the best of it with what you're using.
My point is : Windows is not that bad at all.
I'm still using XP (the best ever) and will continue doing so.
The solution for a good and fast Windows-OS is to use a recovery program (I use Norton Ghost). Windows recovery does not work, never did.
After a new PC-install, add all drivers and software you're going to use on that PC. Add a recovery program and your save for the rest of that 'PC-life'.
In case of problems, doubt or after a few months your windows is getting slow, just run that program and 15 minutes later your OS is as new as it was when you started it. Before you start to run that recovery, do not forget to save documents and mails of course.
Cleaning up a PC is a waste of time and software that supposedly will do it for you is waste of money...! A recovery program is the best investment you should consider.
Chris
Chris
