Has anyone built this engine? If so, I have a question. I am in the process of building a "doubled up" version of the engine. The original plans say the plug holes, which break through the combustion chamber, should be drilled to where the bottom of the hole is .025 from the seat of the intake valve and the bottom of the plug when screwed in should be 1/16" from the bottom of the hole. In my doubled version, should the hole be drilled .050 from the seat and the end of the plug be 1/8" from the bottom of the hole? It would seem that perhaps on something like this, the plug and hole should still be the same distance from the valve seat regardless of size of engine.
