Whittle Aero V8 WIP
Hi Tony,
Hope the back's getting better. It must be something about people who build model engines, I broke my spine about 15 years ago.
Here's my efforts so far. Keep up the great work.
Rob
Very nice Rob,
I'm planning to get in a little shop time tonight. A little, don't want to push things to much. I just started to feel better yesterday!
Tony
I like the lighting, looks like it's gold anodized!
WOW!
I'm trying to turn a little CRS flywheel and drill a couple of holes in it.
I just got back from buying a few drill bits.
Your engine looks fantastic.
SAM
Rob, Ray,
This is pretty cool. 3 of us just about at the same point in the build. We can really compare notes!
Now all we need is GailinNM to drag out his parts. Then there will be 4!
Tony
Rob Tony
Tony Hope back is OK now & not holding the job up
Rob Build looks v.good the cap head screws look really cool on the end caps are they BA or UN
Did 2 hrs on the camshaft did not want to use topslide scale for position of cams so marked out on surface plate I think it would have been easier to transfer DRO from mill to lathe
Good Luck Guys
Ray
Tony, Rob & Ray,
Great looking work by all of you. I have been following along, but have not posted in a while. Before getting to the heads and valves, I wanted to have my hand at some small valves so I have been building a "Tiny" of PutPutMans. It has smaller valves than the Whittle so I thought it would be good experience. I am shut down right now doing some modifications on the lathe, but that will be finished today or tomorrow.
Since I last posted I did get the cylinders all turned and lapped to size. I still need to cut the flats on the fins. I made them out of 41L40. So I am creeping up on it a little bit at a time. I also got the glow plugs in as I found some on sale at a fair price. They had 10 left so I bought all of them.
You guys are giving me inspiration to get back on the project some more.
Gail in NM
Well the back was felling better. I'll let you know tomorrow how better!
Come on Gail join the party!!
Got quit a bit done tonight
Thanks Ray for the flats tip....you saved my Whittle ;D
It actually lines up
The inside
The outside
I'm thinking studs and nuts
No broken things....I was going to tap but my 1-72 where ....shirt. I got to order some new ones. Don't want to break a tap now!
Time for the Rotary Table
Tony
"No broken things". Woo-hoo!
It fits up nice, Tony. Glad you could get into the shop.
Dean
Tony,
Good that your back in the shop. :)
Best Regards
soooo many holes
scary very scary lol
looking fantastic guys
cheers Pete
Hi Tony
Glad your back in the shop & got the chips flying.The part looks good, the critical bit is done the cam & crank holes I can see this finished for the weekend. How do you plan to do the rads mine need improving somehow. EW recommends studs & nuts for the cover plate & hex head for both end caps.The cam is in the lathe with the first cuts done the marking out may not be the preferred method but it worked for me, so far so good.
Ray
Hi Ray,
I plan on turning a stepped pin, 1/4" and the other to fit the screw hole. Pin in vise (1/4) the other in screw hole slowly rotating part as I bring the mill closer and closer (no climb cut or say bye bye). This will be after roughing. I know, don't make much sense but I post pics tonight. Hopefully all that shaping will be over with.
Did you make the cam fixture yet or are you going with spindex or RT?
Tony
That you in the new avatar, Tony?
Snappy lookin' feller, you are.
Dean
Yup, That's me Dean.
Now to the V8. I got a lot done tonight,so here goes
Located the screw holes with a pin gauge after centering RT adjusted vise to pin.
Moved out proper distance...and away we go.
The set up
The cuts
Large radius cuts
The dig out
More to cut
Till Tomorrow
Tony
Tony,
I'm impressed, very neat. :bow: :bow:
Best Regards
That's some very handy work, Tony. It's an impressive looking thing, for sure.
Dean
Wow Tony. Were it me I don't know how I could continue...I'd worry so much about possibly messing up the next operation. Nice going.
