rklopp
- Oct 6, 2008
- 393
- 109
I am building a pair of Nalon Viper 2.5-cc "Diesel" model airplane engines per Ron Chernich's plans purchased from MEN.org. The design calls for two ball bearings to support the crankshaft, one just in front of the crank disk and one just behind the prop driver. I bought shielded bearings. I am wondering whether I should leave all the shields in place, or pry off all but the front one, or all but the front and rear one, or what? If I leave the rear bearing open, the primary compression will be slightly reduced due to the exposed volume of the bearing. Does it matter? I am favoring prying out all but the front one. The crank has 0.001" radial clearance with the crankcase nose bore, so the leak path to the front bearing is fairly choked, but oil should find its way to the front bearing. If I leave all the shields in place, the bearings will be lubed by their native grease.
