Did you use resin-bound sand?In all my 40+ years of foundry experience never seen the use of Wax polished pattens ever. A good quality paint finish with parting powder or, better still…. Brightly polished Aluminium can’t be beaten.
No, not back then. All traditional, old school floor moulding or vibro plate machine.Did you use resin-bound sand?
Top secret, so far.At least what will be the cast surfaces of the flywheel look good and should not require much to get them smooth, machined surfaces are not such an issue.
Now what engine is that going onto?
Any photos from the Foundry this week?
Things aren’t going well currently. We set up for a print of a different flywheel, yet another new model. The first attempt got around 20+ layers before it became detached from the bed plate. Thinking that the plate surface might be contaminated we first washed it with warm water and a very mild detergent. It was then dried and wiped over with diluted Alcohol wipes. Set the program to run again and ended up with with a spider web ball of filament being rolled around the hot plate. Just a small area had adhered to the plate.
Looking at the BambuLabs troubleshooting guide it made reference to cooling the first few layers, see attached screenshot. I spent an hour or so trying to find this option before giving up for the day. Any ideas please?
Cheers Grum.
Edit.
No wonder I could not find it…. It seems I was looking at the X1 troubleshooting guide.
