Hello, I have drill press with a Westinghouse 115 v 311p319A 056 frame type FJ 3/4 hp motor that is spinning the wrong way. it has a simple off on switch and the original wiring cover was missing. I am trying to reverse the direction it is spinning, as i am looking at it underneath there is:
--upper left a spade terminal unlabeled with a black wire going into the windings
--(L1)upper right a post terminal with an attached spade terminal with the post going to an unknown black wire and the post terminal going to a black wire for the one way switch
--middle post terminal unlabeled with a blue wire black wire and green wire
-- (L2)lower post terminal with a yellow wire going to the motor, with attached 2 spade terminals with red wire going to motor and red wire going to switch. thanks
