- Sep 2, 2011
- 1,407
- 415
almost ready to try and start it. had to make a spark plug adapter, some solder tabs for the wires and condensor, a wirel hold down lug which i used a piece of brass and a piece of drill rod and pressed it to make the half moon in the center. all thats left is to set the points cam timing and adjust the valves. (will lock tight the carb and exhaust pipe in once those are set so its easier to work with having them removed right now)
