- Sep 2, 2011
- 1,407
- 415
so ive been thinking about this alot and maybe have some possible solutions i wanted to throw out there and see what you all think. 1 was to do the fly cutter type method. sort of like some use to cut gears with in the hobby, where you make a flat bottom instead of angled bottom fly cutter and grind a hss blank to the profile of the gear tooth or in this case grind it to a parting tool shape to make the grove. i wonder if the chatter and beating would be to much to make a grove that long? the head is just aluminum though so soft cutting.
2 i though of cutting a couple of steel disks to the correct diameter and thickness with a hole in center for an arbor. then while mounted on an arbor put it in the rotary table and use an end mill to sort of cut some teeth all the way around? problems i see here is it would take alot of experimenting to find the right height to set the end mill at and how deep to make the cut. and how many degrees in between each cut. this seems like a whole lot of work for a cutter that probably will not last long and possibly the aluminum would gob up the teeth of the cutter?
does anyone happen to have coppies of strictly ic magazine. issues 63-66 ? im hoping he gives more information about how he did it in those articles. i looked at sic's website and looks like i have to mail in an order and then wait for hard coppies to come back. which im not opposed to doing or paying for but just would take some time and is a risk that it may not even have any info on that part of the engine build.
