ziggy12345
New Member
- Aug 29, 2013
- 3
- 0
Hi
I have had a Warco 280V-F for a couple of months and have had multiple problems. Firstly I was using it fine then after starting one day the motor sped up really fast and blew the fuse. This happened about 5 times in a row.
I changed the main board and it was fine for 2-4 starts then went again.
An engineer came around from Warco and he changed the board and it did the same but this time blowing the MOSFETS.
After this he changed the motor and it was fine again until just now. I switched the lathe on and it blew the MOSFETS on the main board.
I spoke to WARCO and the engineer said I was starting the lathe wrong. I have to reduce the speed first then start the lathe then increase the speed to what I require. This sounds a lot like BS to me.
Anyway they are sending me yet another new board to try.
I would have thought there was some sort of breaker that would pop and I could reset it and carry on.
Any thoughts? I will send the lathe back if the board goes again
