Grapegro--I have built eight i.c. engines, and used a single Viton o-ring on all of them. I seen your post when it first went up, but didn't respond because I work in British Imperial not metric. Since it seems that you have not received an answer to your question this is what I know from experience. First, you only require one Viton ring. Two are not necessary, and add too much drag to the piston. The cylinder on my most recent engine was 1" (25.4mm) bore. The piston was made .0015" (.038mm) smaller in diameter so it had an outer diameter of 0.998" (25.36mm). The viton o-ring that I use has a NOMINAL cross section diameter of 1/16" (1.59mm). However, in reality the o-ring has a cross sectional diameter of 0.070" (1.78mm). I make the groove in my piston .093" (2.36mm) wide, x .057" (1.45mm) deep. This works very well, allowing the proper clearances to seal the piston effectively but still let it slide freely enough in the cylinder without binding. I run an approximate 30:1 mix of Naptha gas with two cycle engine oil to run my engines on, in order to supply lubrication for the ring. It is a good idea to lap the cylinder bore with 600 grit lapping paste to get a very smooth finish. If you don't have a very good "almost mirror" finish on the inside of the cylinder it will tear up the Viton o-ring very quickly.---Brian
