Things are moving right along... got the steam ports in the cylinder, finished the valve assembly, finished the reversing gear, got the oak lagging done, got all the gaskets cut out(just have to punch the bolt holes in them), so the ONLY machining left to do is the piston! (Then a whole lot of tweaking to get 'er running, I don't doubt!) Next time you see this engine will be "first run"
Valve Assembly
Reversing gear fitted
Trial fit of lagging
Cheers, Joe
Valve Assembly
Cheers, Joe
