Valve seat materials?
JimSvarv
Active Member
Sweden
Hello!
I'm wondering what materials I could use for valve seats?
I have difficulty finding cast iron in my location and bearing bronze is quite expensive, especially for a simple project as I had in mind.
Could I just use normal construction steel? I have free machining lead steel and ɓrass too if it would work better?
Maybe I could find some junk break rotor and use, but it would tricky to make pieces that could be easy to hold.
Watching for interest, ................. how ever aren't most seat slightly hard(ened) ??
However given what material you have on hand I would say leaded steal....
Brass for guides, 1144 steel for seats.
The 1144 steel would be best. But any steel you have would work, but I would not use the leaded steel, that is for screw machines as an easy free maching material. It is made to save time and tooling machinging, because the .15-.35 lead content is softer and the swarf break off easier. Of course lead is about banned everywhere. Not supposed to handle it. It doe not seem as easy to find now days.
Some people use it for bearings.
I would not use brass either, hardened valve seats are used as exhaust valve seats. Oldy enough, when lead was used in gasoline, it prolonged the life of castiron head seats and allowed higher compression, preventing detonation.
When they removed the lead, seats went out in about 10,000 miles. The intake seats did not wear out. Hardened seats are used now in almuinum heads.
Matt Clarke
Hello!
304 stainless steel
Oddly enough, I was at a garage sale and the guy had broken up a piano (sigh) and the iron in it I was able to obtain. Altho' very odd shapes, I am cutting it into parts and cleaning them up. in the larger parts is a lot of holes but the smaller parts can be used for various small parts like small pistons and what not. ONe of my colleagues wondered why I had gotten it, well, just because CI is pretty hard to find where I am now and expensive if I had to buy it. Don't know yet about the quality, but will find out.
You said you are building a Webster type engine. Since you have brass it should work fine in a model engine like the Webster. Models are lightly loaded and do not run thousands of hours.
I believe Steve Huck uses brass valve cages in his LiL Demon V8 which has run quite a few hours at the model shows.
You could also use your leaded steel.
Any grey cast iron is OK to use, unless magnetised! Or any mild steel is OK, it will last longer, but wear valves quicker than cast iron. On a model it is likely you'll never do the 1000hours to wear things to replacement service time. - 200 shows running 5 hours average? I modeller I knew reckoned his 9 cylinder radial only ran for about 10 hours before he was losing compression with piston rings though. He never had a problem with valve/seat wear.
I did turn two valve cages from C45, I think it's similar to 1144.
I did also try make a valve from it but that was much harder, ended up snapping the valve stem.
I will see if I can get some stainless countersink screws and use them for valves.
Kinda sad if a engine only lasts 10h especially a 9 cylinder radial, must be a lot of time invested in that.
I also read about some engines only lasting a few flights in model planes.
But on other hand if my engine lasts 10h I'm happy, webster lacking any cooling will also not run very long.
I agree with kuhncw here......use the materials for the duty expected. Brass valve guides with leaded steel valves. They cut cleanly and unlikely need any lap in to each other. For those just exploring model engine builds looking at a 1st project, it would be better to use valve guides as an insert to the head or block rather than machine direct into a major part.
