- Dec 2, 2008
- 971
- 9
Hi Y'all
I need a little help with valve timeing for compressed air engine. There have been a number of discussions here and elswhere and I think I understand such concepts as lead, cutoff, expansion and how to modify the dimensions to produce change, but I don't think I have ever seen any discussion on the overlap of timing between adjacent cylinders in a multi-cylinder engine. For example, on the three cylinder swash plate engine that I am building, if steam of HPA is admitted to each cyl for 160deg in the cycle then during 40 deg of each cylinders's power stroke, the source of air or steam is shared with another cylinder. Is it better to limit each cylinder's share of the power to 120 degrees or less so that there is no overlap or does it really matter?
Thanks for your thoughts or experience.
Jerry
Jerry
