The two conrods on a common crankpin seems to work OK for Harley Davidson so I'm sure Brian's will too. It's not a lot different in general layout to the Hoglet model engine and they run OK too.
I don't know. Brian has the snowmobile coil that he used on another twin. Apparently the two cylinders are 40° out of sync so I am not sure how that would work out. I think that it would fire at TDC (0°) then 40° and then again at TDCA second-hand motorcycle coil should be considered.
Gordon, is the snowmobile engine a 90 degree Vee?
I have an idea that a coil that fires through 2 leads simultaneously (redundant spark) should work, but I haven't yet sat at the board and drawn the cycles to see where the redundant sparks fire.
Is that what the snowmobile coil does?
A set of eight for a Ford eBay US as low as $32£100 each in the UK (New), so even junk yard COPs are not cheap.
