You have left yourself a fair bit of lapping to do if those ali pistons are to run freely when hot.
I know what I'm going to do tomorrow. I won't actually cut to the layout lines. All positioning will be done with my X and Y dro's on the milling machine. The layout lines and punch marks are only there to keep me from dialing in something wildly wrong.
It is 96% tin and 4% silver solder and is sold by Oatey,
I researched Oatley product #48319 out of curiosity. In the Q and A section Oatley responded that the silver content is less than 2% for that product.Just be aware that the solder you say you have got is not 4% silver / 96% Tin as spec'd on the drawings so may affect the joint strength. The 4/96 is a high tensile solder often used for HVAC as a replacement for silver braze. Oatey don't give strengths for what you have but I would think it could be as low as half the stength of a 4/96 solder.
Upto you whether you change it now or risk joint failure later.
good point on the sealed bearings. on my single i used sealed bearings but also put a little silicone on the crank as i slid it in the bearings so it would seal there as well. just a very little bit and was on final assembly after it has already been ran and torn down for sealing all over. bout the only leak i get now is a little oil vapor wetting around the vent.Looking good, Brian.
I will stick my neck out and suggest that to avoid marking up aluminum in a chuck, you cut a strip of soft drink can aluminum and wrap the piece in it before clamping.
The other point I'll make is that if I remember correctly, the original Upshur design leaked oil past the crankshaft. The solution was to use sealed ball bearings or put shaft seals in place.
Thats all I remember from others who built the engine (except the one guy who built it upside down whereupon it leaked very badly).
