Hi Mati;
Ignition is using the breaker points as set out in the plans, a 6v automotive coil, condenser (capacitor), and a 6v lantern battery. I use this on other engines also with no troubles. The carburetor is to the drawings also,
it has no air bleed or capacity to meter fuel to throttle position. Works best at a set speed.
Thanks for looking and I will read your thread.
Peter
