Tyres - How?
RManley
Has anyone had a go at making scale tyres for their projects?
I know that most people stop at the engines but I want to go that little bit further and try to make some realistic tyres. More specifically - classic motorcycle tyres for a 10" wheel rim.
I have seen these little balance bikes for toddlers with what looks like custom tyres with some sort of tread pattern which I assume is made is CH in their 1000's. I want to replicate this but in 10's....
Any ideas?
R
Hi R , The easiest way to replicate tyres is by using silicone rubber to cast them in a mould. The tread pattern can be as simple or complex as your mould making skills will allow , the rubber can be coloured black just like " real " tyres.
Another method would be to have the tyres 3D printed in which case the detail will be no problem , including side wall lettering assuming your pockets are deep enough.
Silicone rubbers are very versatile , can be cast in a variety of colours and hardness, they can also be bonded to a metal substrate.
I am just down the road from you and you can email me for further information on 3D cad/printing or using silicone rubbers.
Dan.
Where are you based Dan?
You've got my interest going. I will have a go at 3D modelling some tyres over the next few weeks but I will lean on you for your experience in silicone rubber moulding.
Do you have any examples of what you have done?
Thanks R
That is an impressive looking model - Im slowly getting some ideas together, thanks fellas
R
Here's something I posted some 5 years back on moulding with polyurethane & Silicone resins.
http://www.homemodelenginemachinist.com/showthread.php?t=15298
You can throw a silcone mould (negative) from a suitable (positive) sample, hand carved or 3D printed model.
Followed by gravity or vacuum/pressure casting to reproduce as many positives as you like.
For tyres I would use polyurethane in a silicone mould.
Ken
