Hi another question for my project.
fixing up a old tumbler,
it uses 2 drive shafts to rotate the tumbler drums.
I am re making the wheels and posted about that, I currently am trying to select material for the drive shafts and have a few options
I can use the stock set up, using this sort of pillow block (bronze or oilite)
I need a strong shaft 3/4 thick and unsure which would be good for that bearing and hold the weight of the tumbler drums and content.
the other option is to try fitting pillow blocks but with ball bearings, not sure I can fit this into the stock design.
so hopefully the suggested steel rod for the oilite will work for whichever I end up with.
