Pretty simple question: how much torque is needed for the MT3 drawbar on my mini mill? I hate doing things by feel.
Hanermo3, I understand what you are saying, but there are MT collets available that need to be tight enough to hold the cutters. If it's just a MT shank on the end of a collet holder, that's a different situation.
Paul.
I think the issue I'm having isn't the drawbar being too loose, but that the drawbar keeps loosening up on me while being used. I think I'll try Loctite on the drawbar to keep it in place.
Loctite what exactly? This should not be necessary. If the drawbar is coming loose there is something wrong.I think the issue I'm having isn't the drawbar being too loose, but that the drawbar keeps loosening up on me while being used. I think I'll try Loctite on the drawbar to keep it in place.
Loctite on the drawbar threads. It doesn't surprise me that it's loosening considering it's not very tight, is spinning at 1,000RPM, and the head can vibrate.Loctite what exactly? This should not be necessary. If the drawbar is coming loose there is something wrong.
As I don't know your level of knowledge I am asking probably dumb questions to try to make sure we are all singing from the same sheet to get to the bottom of this for you.Loctite on the drawbar threads. It doesn't surprise me that it's loosening considering it's not very tight, is spinning at 1,000RPM, and the head can vibrate.
I just have a X2 mini mill and its drawbar is only threaded on the end which engages the tool, like this:As I don't know your level of knowledge I am asking probably dumb questions to try to make sure we are all singing from the same sheet to get to the bottom of this for you.
Which threads? The drawbar should have threads at both ends, at the bottom to screw into the back of the taper you want to hold, and at the top to allow the retaining nut to be screwed down onto the top of the spindle to tighten the assembly. Is your configuration in some way different?
Tapers are in good shape. In fact, I just replaced the spindle.Hi Zoltan
What is the condition of the Morse tapers both in the spindle and the surface of the external taper as any burrs or swarf will not allow them to seat properly and may be the cause of the vibrations.
Remember thumb on the wrench head that is on the lock bolt and use small digits to nip up the bolt is normally enough to secure it.
Is the collar that is in the top of the spindle in place and lightly oiled.
Check your spindle speed and feed rate for the size of the cutter and the hardness of the metal that is being milled as this is often a cause of vibration.
Eric
