When electric screwdrivers appeared I couldnt see the point but after I got one I wouldnt be without one.
On the lathe the two things I didnt know I needed until I got them are:
the quick change toolpost I now (almost) always use the proper tool rather than make do with what was last in the toolpost and the tool is properly set up rather than near enough for that quick job.
A chamfer tool before I had this if I needed to take the corner off a piece of work I would probably take shortcuts rather than set the cross slide over. With the chamfer tool (and the QCTP) I now make neat consistent and repeatable chamfers every time.
I would be interested to hear if there is anything else (other than essentials) that I dont know I need and then cant do without.
John S
John S
