Hi
Well I have been playing about with this a little more and I'm now getting somewhere. I am going to use belts with the T5 profile, they are readily available and reasonably priced. I will have to make quite a few pulleys for a few projects I have in mind so I decided to make a bit of kit that I will be able to use many times. Basically what I have done is to use the slitting saw idea but regrind the blade. First of all here's a sketch of the T5 tooth profile.
Next job was to make a gadget that fits into the lathe tool post and a grinding wheel mounted in the chuck on an arbor. I have used the insides of an old wiper motor to control the tool.
Here's a video of the tool in action. Note I have the lath covered with newspaper to protect it from grinding dust.
[ame]http://www.youtube.com/watch?v=W-SId6h5ans[/ame]
The slitting saw after re grinding
Setting up in the mill.
About half way round cutting a 24 tooth pulley. The blank is actually 2 pieces of 6mm aluminium clamped and turned together as a test piece.
Finished cutting
The belt is a good fit in the pulley.
It needs the tops of the teeth rounding over slightly but I can do that easily with a small file.
I think I have it cracked now. I have a lot more photos if anyone is interested in more details.
Rich
