HaydenI said:
GWRdriver, i didnt know about them drawings but no matter . . .
Right. No matter, I also would have ended up redrawing, and have redrawn, the entire engine so it didn't matter at all whether I started with drawing for the 3.5"ga version or the 2X version. Forge ahead!
As for the cylinders, I elected to make a pattern and have them cast so on that account I could do whatever I wanted to do. But I spent some time corresponding with folks in the UK (and one in the US) who had either built, or run, or owned the 2X, about what if anything they would do to improve operation, performance, etc, and in every single case the recommendation was to increase the cylinder bores by at least 1/8". There was even a recommendation to go to alternative cylinder castings (from the 5"ga Simplex IIRC) but that change didn't look right on paper, and wouldn't match my throw, thus the new castings. This change not only increased power but resulted in a better performer in general and made it a pleasure to drive. The stock boiler design was apparently sufficient to absorb this change without any difficulty.
Another strong recommendation was to "lock" the rear axle, that is, to make it rigid and unsprung so as to create a three-point suspension. This apparently results in a more stable ride, less pitching on uneven track, more adhesive weight on the drivers, and in general better handling for an 0-4-0. I had already sprung my rear axle in the usual way but it can easily be locked so that I can eventually try it both ways.
Kvom, as for the Belpaire boiler, . . . there's really no other reason other than I just like them. I've built several and find them easier to build and stay at the firebox end than round tops, and the TICH looks good with one, so it's simply a personal preference.
Harry
