terryd
All the above reminded me of this item for turning slender rod and perhaps if you had a few to do it might be possible to adapt the idea to support the threaded diameter behind the die???
John B
Hi,
The tailstock holder which I posted a picture of earlier has an 8mm hole all the way through to the headstock which controls any whip in long slender rods. I have batch produced threaded 5/32 rods (4mm) BSW (approx #8-32 UNC) which are 11.5" long without any drunkenness in the thread, so I don't think that this is a problem with a decent tailstock die holder. I can use this system for up to M8 (5/16") threads, above this I use single point threading. I wouldn't use single point threading for small threads as quality split dies are available at reasonable prices. I find that brass cuts beautifully
There is a Youtube video showing a long thin threaded rod (for Meccano use) made using my tailstock holder here
![Thread cut.JPG Thread cut.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/69/69930-0328609300f0f18de29699934d784000.jpg)
Above - the Meccano coupler on the threaded rod is internally threaded and 1.125" long, thread 5/32 BSW.
Above - here I am cutting an M2 (2mm - just smaller than #2-64 UNF) thread
TerryD
