The Sherline's gettin' some love
I'm sorry about that last post, my computer locked up in the middle of actually posting it, and the post got hosed up. I re-booted the computer and it's playing nicer now.
The post should have looked like this:
It doesn't show in the model I posted, but one of the screws I kept forgetting to model is directly under the slot in the cross-slide. There IS room there, I've got 40mm of separation between te top of the cross-slide and the top of the carriage scale. But it would need a major redesign of at least three of the brackets. Still, it's something to keep in mind for the future.
OK, good news - bad news.
The good news is that when I came downstairs this morning I found this rather unimposing pile of parts on the build-plate, instead of the rats nest I was afraid I'd find.
You gotta love those magnetic build-plates, all the parts just popped loose when I pulled the plate out of the D6. Initial inspection showed that all of the parts looked good, and all of the holes lined up like the model said they would.
I did a little sanding on the surfaces that needed to mate together, just to be sure the printed surfaces were flat. There are only two parts that I couldn't build any adjustment into, the cross-slide scale mounting bracket in the upper RH corner of the photo, and the carriage read-head mounting bracket in the lower LH corner. The cross-slide bracket slides into the T-slot on the slide and uses the slot as its' anchor point. The carriage bracket uses those two screws that I kept forgetting to model as its' anchor point. The bad news is that neither one of these parts actually fit.
The cross-slide bracket did not fit in the slot. Since this part is supposed to fit in the T-slot so it has a complex cross section. To avoid the need for supports I print this with its' RH side, as you see it in the photo, on the print bed. This orientation also makes it the tallest part. With its' small cross section at this point in the print there's not much time for the plastic to cool between layers, even with the cooling fan at 100%. So I got a little sag, not unexpected, so that was attacked with the files - still didn't fit. I checked the thickness of the web that fits in the slot. The slot is 6.4mm wide, the web is 6mm thick, I checked the depth of the slot the flanges fit into, it's 2.6mm - the flanges are 2mm thick so they're OK. I checked the overall width of the slot for the flanges and it's 10mm, ish. The flanges measure ... 11mm? WTF, how'd that happen? Oh well, I can always mill 0.5mm off each flange - Easee-Peasee.
On to the carriage bracket problems. Remember those two screws? Well there weren't two, there were three. I forgot about the 8-32 SHCS that secures the tapered gib for the carriage. I modeled them last night, LATE last night. I wanted to get the print started before I went to bed. I hand drew a sketch of the screws and their sizes/locations. The 3D model "Sketch" I was working with was inverted to my hand sketch, so I flipped my hand sketch over. I didn't want to model a mirror image of what I actually wanted. That SHCS is one of the problems with the bracket. The head of that screw is 7.62mm in diameter, I only allowed an 8mm slot. With my FDM 3D printers that ain't enough clearance fo r comfort Clarence, it's WAY too snug. The other problem with this bracket is the location of the slot for the existing screw at the tailstock end of the cross-slide, it's off by about a mm. This one needs a re-print.
Oh well, since I've got to fix and re-print the carriage bracket, I might as well fix and reprint the cross-slide bracket too. To avoid any further issues with the cross-slide bracket I attacked the flanges with the belt sander, just as a sanity check to be sure there weren't anymore problems - fits like a glove.
The lathe looking great
Remember the old days everthing work great.
I found this workers ever time and never need power or batteries. Take off shelf day night and works
This on my desk and used it too.
Works by candle light too
This off the internet looks new
https://sliderulemuseum.com/VirtualSR2/react/nestler_23r.html
Use C & D SCALE
I finished the fixes on the cross-slide and the carriage bracket models. They're re-printing now and should be done in a couple more hours, it takes a while to print 50mm in height with 0.2mm layers. It's done with the flat part of the carriage bracket so the layers will go faster. I really need to get my resin printer set up and running.
Meanwhile, I can at least take the old scales off the lathe and start installing the new scales.
The print completed, but they still didn't fit right off the printer. The carriage bracket still isn't right on the headstock end, the slots aren't deep enough. But ya' know what? A Dremel and a rotary burr fixed that problem REAL fast, I am NOT printing that sucker again. I am going to modify the 3D model though. That way if I ever DO have to re-print the bracket it will be a little closer to accurate. The cross-slide bracket was fitting too tight. A few licks with a file and some sandpaper fixed that problem. I powered up the new scales with the AC adapter, to verify which way the scales read. Then I marked them with tape as to which end went where and which direction was up.
Now I just need to install some heat set inserts, drill and tap a couple holes in the base, and do the final install. I also need to find my micro screwdrivers so I can open the battery cover. That way I can at least use the scales with batteries until I can get another plug and make a Y connector for the AC adapter.
The scales upgrade on the Sherline is mostly complete. Here's what things look like from the front.
As you can see, I'm no longer losing 35-40mm of carriage travel at the tailstock end due to the cross-slide scale. And the cross-slide scale is no longer a shelf where chips and dust will accumulate.
This is what the back side of the scale install looks like - from the headstock end. The carriage scale in no longer a shelf that chips and dirt to land on. Both the cross-slide and the carriage scale have the actual "scale" facing away from the spindle, so they aren't directly exposed to hot chips.
That black object on the LH side of the cross-slide read-head is an end stop. Before I installed that, it wasn't uncommon for me to retract the cross-slide far enough to disengage the lead screw from the lead nut. While that wasn't a show-stopper, it was irritating. That won't happen any more.
This is the temporary location of the displays.
The brackets that came with the scales didn't work for me. They allowed you to swing the display from side to side on an arm that was 8-9" long. They did not allow any tilting of the display for a better viewing angle. I 3D printed a pair of stubby arms, about 2" long, that allow me to tilt the displays to the best angle - whether I'm standing or sitting.
There's still a few things on the To-Do list:
1) Find a more permanent home for the displays. Right now I'm leaning toward mounting them on the peg-board using some of that brown non-conductive organic material - probably about where the pin-punch set is hanging behind the 3-in-1 oil.
2) Do some cable management, not gonna get crazy with the excess cable like I did the first time. Behind the peg-board is a blocked off door that at one time went into the coal-room, for when the boiler was coal-fired. I may just let the extra cable hang in that space, it's not like I can actually use the space for any thing else.
3) I've got to find another plug and get the AC adapter modified so it will be able to power both units. Somebody might already make a Y-adapter in the right size, I'll have to check Digi-Key and Allied-Electronics to find out
Like Superfast Matt I tend to get things to the point where I can use them, then they never truly get finished. But they are good enough to use, and right now this one is "Good Enough".
I've also got the replacement spindle bearings for the Sherline, I got tapered roller bearings to replace the noisy deep-groove ball bearings, That project is on the "Someday" list too.
Thanks clockworkcheval, deeply appreciated.
I just found the Y adapter. They are a 3.5mmODx1.35mmID barrel connector, and you'll need a female to two males adapter cable. I found them on Ebay, DC Y splitter, but I had to buy two of them to get the one that I needed. Oh well, it'll still be cheaper than batteries.
