- Jan 17, 2009
- 1,081
- 278
can the part be better designed ?
Dan.
That should always be the first question when faced with a difficult operation.
Dan.
OK, advice on this problem I'm going to be up against. I want to tap an 8-32 hole that is only 0.150 to 0.165 deep. Hey, it is what I'm up against. I plan to drill the hole depth with a number 29 (0.136). Find zero on my Bridgeport and raise the table, 0.160. Then I have an extra 9/64 end mill that I ground flat on my diamond wheel grinder and use that to flatten the bottom of the hole. I do have a spare 8-32 tap that I ground flat also that I've been using with good results after starting with a taper tap when possible. I have a lot of spare taps that if a taper tap needs some taken off, I can do it. Then a plug tap, then my bottoming tap. I haven't done anything yet as I want to get as much advice before I start this tapping of 16 holes!!!
H. What s "break-free tapping oil"..ThanksSomething that has not been mentioned is to use break-free for tapping oil when using tiny taps. Not cutting oil per se, but with it, the taps don't get stuck.
