Taper tool for mini lathe?
M
MadKad
Guest
Hi
I am looking into making a taper tool that would attach to my mini lathe like a tool post, I have a good idea but I am unsure if it will work, I was going to draw it up but its been that long since I drew something on my pc I forgot how to use the programs lol
Any one made one? or got any ideas?
I know there is one here : http://www.gadgetbuilder.com/Taper.html
but that to me isnt practicle (still good though) I just wouldnt like to have to adapt my lathe in such a way :)
Hi
ok I did this design and wanted to see anyones thoughts on it
http://www.madkad.co.uk/taper/taper.html
its a PDF file show page, you can click the image and then see it by holding down the mouse and moving round to view the model.
just my idea, any thoughts?
MadKad:
I may be missing something here but here is my perspective.
I was fortunate enough to find a a south bend Lathe with factory original taper attachment installed so not real need for me to build one.
Keep in mind there are three ways to cut a taper on a lathe well maybe four.
1 Taper attachment
2 set compound to angle
3 Tail stock offset method.
3a offset live center adapter
To me the taper attachment on the gadget builder looks very usable.
I fail to see the logic behind your design. I do not see how it would work. Not to be smart here but have you ever used a taper attachment do you understand how they work?
Thanks for the reply mate, I haven't used a taper attachment, but I really missed out on that pic on what it would do.
Basically I would do it so that the tool post on the taper attachment would move side to side, this taper attachment would go on my lathe where the compound slide goes normally, then it would be set to the degree needed, so when the tool post slides to the right it moves more to the center at the same time.
So cutting a taper with the taper attachment on and all set, you could move the x axis in a bit at a time to take off the amount needed each time till the taper is made to the length wanted.
That was hard to try and explain, I could make the image a little better to show more, but would like some ideas on if it would work first really lol.
I do like the other one, the only thing is that there looks like there is allot of bolting to the lathe etc, with this one it would be just the standard 2 bolt where the compound slide fits also.
MadKad,
Have you seen the article by Dave Fenner in the August "Model Engineering Workshop" magazine (issue #141)? In it he shows the construction of an attachment similar to the gadgetbuilder one for use on a Seig C3 lathe.
It may not be what you want - but might provide some more food for thought.
Tony.
agr said:
MadKad,
Tony.
Hi sorry I dont get magazine's but I would have loved to have read that article :)
A great base for a taper attachment would be a linear slide. Like the low profile NSK ones. It would save a lot of work. I had though about building one until I got a machine that has one, which I still have never used. ::)
Use a boring head in the tailstock.
Nothing to make and it still works as a boring head.
Nice thats an intresting idea, two things though:
1. whats that in the cuck? and is it needed?
2. how do you get the right deigre needed?
Thanks guys by the way
MK,
The item in the chuck I think you are referring to is the driver (in this case a bolt) which is creating the rotation to the job as it is suspended between centres by being pushed around by the jaw of the chuck.
The angle is worked out by simple (for some) trignometry, ie. tangent of angle required * adjacent = opposite (distance to offset).
Sir John I keep seeing pictures of that method and it looks so simple.:)
One thing keeps nagging away at me though. How do you insure that the ball gizmo/boring head stays on center....just keep slapping her in and checking until you get lucky or adjust it carefully then whack it in with one of Boggie's old lead hammers.;)
Also, are those shop made ball widgets or can they be purchased cheaply. I think I may have a bit of Yorkie blood running in my veins from long ago.
I like the idea of that way, but I really think I would have truble setting up for the taper to be correct it would take me to long, with my way I would just set the taper tool like you would with the compound slide.
but I just need to work out how I could get it to slide left and right smoothly
Just slam it in, the MK1 eyeball is more accurate than you think ;)
Better description:-
You need a piece of bar the same size as the boring tool to fit the head, usually 1/2" centre drill one end and fit into the boring head centre drilled hole outwards.
Then get a piece of round material in the 3 jaw, not critical and center drill that.
DON'T REMOVE FROM THE CHUCK.
Now place your part between these inverse centers with a ball bearing in each end and drive with a dog on the part as in the pick.
Any sort of dog or clamp will do it doesn't have to win prizes so pretty isn't part of the equation.
The reason to use the ball bearings is that if you were using normal centers you would get mis alignment, with the balls it's a perfect full contact surface.
It's possible we had the same engineering teacher ;) .............. or perhaps they were brothers ::)
CC
AHAH! (Blinding light switches on over the ol' noggin.) A good, used ball bearing sits in a tapered hole wid some lube smeared on. Yup, that's cheap & cheerful allright.;D
Sorry John, must get a bigger monitor, didn't see the ball ends on your photo,but at least we made Dickey think. :big:
Surprised the Pop Mech originator hasn't picked up on that one though? Having said that, quite a few illustrations show offset turning with pointy centres (centers)
Regards Ian.
John Stevenson---Absolutely brilliant solution, using the boring head to taper turn, along with the ball bearings. What a great idea. Now I have one more justification to purchase a boring head for my Craftex mill.---Brian
