taper end mill
canadianhorsepower
Hi gang,:)
I'm trying to purchase a set of taper end mill :rolleyes:
and have no sucess I don't know if I'm not calling
the proper way
some reference pleaseThm:
If you need to mill an angle you would set the angle required by
A: setting the desired angle by off-setting the head or
B: clamping the work at the desired angle to the cutter in the spindle.
A:
images
B:
n4zou: I know that, but it's exc
actly what I dont want to do
thanks
May I suggest you contact these people:
J.R.'s Tool Crib Inc.
(330) 784-7444 phone
(330) 784-7480 fax
[email protected] email
I have no connection with them except as a very satisfied customer. An exchange of a couple of e-mails led to me getting 'just what the doctor ordered' from a very friendly family concern.
Geoff
P.S. No, I didn't really know what I was looking-for, so they guided me towards an affordable solution.
try a google for Tapered End Mills may not find sets but a lot out there.
MSC lists 1137 diferent ones ranging from 1/2 degree per side taper to 45 degrees per side asorted sizes and materials.
MSC means what??
MSC means what??
MSC is an industrial supply company like McMaster Carr.
Best thing to do here is order the endmill you need and not a set. Spend your hard earned on a good quality cutter instead of a set of cheap cutters that you will use only half of.
What angle and depth of cut are you needing? If known I can help you locate one.
MSC originality known as Manhattan supply company . or sid tool.
there catalog is hardbound and 4 inches thick arguably the largest industrial supplier in north america.
MSCdirect.com
