goldstar31
Al,
Coffee not working yet, mind in slow motion....can you elaborate on your system for a newbie? I've just used my tailstock to pinpoint..
Jim
In GadgetBuilder.com's site it is called a Bump Center
Norm
Al,
Jim
This is going to require some "fun" in the shop to test. I'm very intrigued. Thanks for enlightening me.In GadgetBuilder.com's site it is called a Bump Center
Norm
The square stock is mounted in the tool holder with the bearing vertical. The square stock is either perpendicular to or inline with the axis of the spindle, depending on which face you want to align.
With your work piece snug in the chuck, you slowly advance the bearing in toward the workpiece. Contact will be made at the "high" spot on the work piece, and the bearing will push the work piece a bit "lower." Eventually the bearing will be making light contact with the entire piece, and the piece is aligned. You can then finish tightening the chuck.
I made one a few years ago -
Worded very well, added to the visual above I think I'm buying in to the process. Thanks, JimThe square stock is mounted in the tool holder with the bearing vertical. The square stock is either perpendicular to or inline with the axis of the spindle, depending on which face you want to align.
The Chinese chucks are well worth the money but its worth the effort to strip down and clean
I also take off the sharp edges even the gear teeth.As has been said a light coat of grease
once tried oil and learned by my mistake it tends to get thrown everywhere
