JMI
Greetings,
It has been quite some time since I have posted. I had moved to a job site where there wasn't access to machine tools but the situation has changed and I'm back in the saddle again. ;D
Me thinks an Elmer's Mine Engine #29 is in the future. Was wondering if this 5-C Collet Index (the G5650 from Grizzly) could be used to cut the radius on the cylinder.
Can the index be mounted horizontally on the milling machine and the index be rotated while the cutting tool is removing metal? Or are indexing devices meant to be rotated then a cut is preformed? I know this may sound like a simple question but I don't want to spend the money only to discover that the tool is being misused.
I built Elmer's #33 Mill Engine with the same cylinder but used a rotary table in the vertical position. This time I'd like to try using the indexer assuming it is meant for that.
TIA
Jim
TIA
Jim
