This build thread will detail the design and construction of a 10-Stage, axial flow, Parson’s type turbine. The steam generator (aka, boiler) for this turbine will copy the SES Boiler-Burner design developed in the mid 1970’s for automotive use and has proven steam output of 10 LPM at 1000 F (538 C) at 1000 psi, and will be covered in a separate thread.
This turbine will use water as the working fluid, and will therefore need multiple rotor-stator stages to extract as much of the steam’s energy as possible. Modern power plants use steam turbines with 20 or more rotor-stator pairs which allow the steam to expand around 800 time. These turbines are very energy efficient, but they are also quite large and complex. My end use needs a mobile engine, so I've made a compromise between greatest efficiency and simplest, smallest design; 10 rotor-stator pairs should extract the majority of the steam's energy.
The high temperature & pressure I plan to use requires extensive use of stainless steel; the turbine case, nozzle, and stators are all made from 304 stainless. Heavy grid-lines in the drawing below are 1 inch.
I chose to use a split case design as it allows for easy assembly & diss-assembly and also provides for good visual checks of blade clearance, but of course the split case will also be a challenge to properly seal.
The finished case is made up from 4 separate pieces; top & bottom high-pressure section, which is welded to the top & bottom low-pressure section.
High pressure case halves were machined from a single block of 304 stainless, which was cut in half.
Each half was machined on my CNC mill and lathe.
