Carrying on from where I left off in post 292 where I squashed the water pump body, I now have a new body soldered together. So, the next step was to hold it in the 4 Jaw chuck without squashing the new part, I turned up a holder out of aluminium with a couple of screws on the side to hold the part. The bore is offset .064" which translates to a total indicator reading of .128"when offset in the chuck.
This made turning the part easy, it was later counter bored and screw cut.
The cap that screws on to the body is made out of delrin, however that didn't go too well when it decided to break. What to do next? I thought as long as the material is non magnetic, some thing else will be ok, so I used some brass. It has to be non magnetic to allow the magnetic drive to work on the impeller.
Next step was to glue the magnets into the impeller and pulley, I used another piece of 1/8" dia carbide for the pivot on the impeller.
I soldered the inlet onto the back of the main body, then set it up in the mill at the correct angle and machined the outlet hole in the side. I decided to align the outlet in the hole with a piece of 1/4" dia carbide, reasoning that the solder wont stick to the shank. I made sure that the solder was flowing between the parts before holding it down while it cooled.
Here is the main body with the circular insert fitted inside, it's loctited in as well as held with a pin from the back, there's also an assembled picture.
All that's left now is to make a clamping bracket that screws on the back, as well as clean it all up a bit.
Paul.
