Swifty
I managed to finish the oil pump today, as suggested on the drawing, I used some carbide shafting for the pins on the gears. They were broken cutter shanks that I had kept, the long shaft runs on 2 bearings and also 2 "O" rings, "O"rings can be very hard on shafting and wear it away. The smaller carbide pin came out of a longer piece, I just used the corner of the diamond cup wheel to score the outside as much as I could, then snapped it with a pair of pliers. The ends were cleaned up to size in my cutter grinder.
One gear has been loctited to the long shaft, and the short shaft has been loctited in the top plate. I'll give it 24 hours to cure properly and then do the final assembly.
Just for something different for a change, I cut up the brass bar that will be the radiator fins, bored a hole in a scrap block and tapped M8 in the side to hold the bars for facing. The brass is all out of the same bar, and very consistent in size across corners, the sides are all within .001" of centre, I'm not sure if I will use the same fixture to cut the fins, I already have another idea forming in my mind, will see what happens.
Paul.
Paul.
