Mechanicboy
- Jul 10, 2013
- 959
- 349
Crank at 180 degree will not selfstart when the steam engine has double acting cylinders. Better set crank at 90 degree to selfstart.
Wasn't sure if the cranks should be 180 apart or the same. Photos I have seen have them most of the time haphazardly, so the idea of balance seemed appropriate in this case so 180 it is. Then assembled all that on the crankshaft, lined things up and lightly tightened them down so as to not score the crankshaft too badly at this point. Not sure if I can upload video here or need to upload somewhere else and link it so will do a different post for that. But, with all the weight and piston rods and eccentrics dragging it still turns smoothly without a lot of effort, and it isn't lubed yet.
That has been modified and shown in one of the more recent posts.Nope, 180 is "wrong".
When you have them at 180, both cylinders will be on "dead center" at the same time. in that case, the engine can't always self-start.
You want them set at 90 degrees to each other. That way one is at mid-stroke when the other is at dead center. Applying steam/air and the engine will start running without needed the flywheel to be pushed over by hand.
There's nothing to say you *CAN'T* have it at 180, if that's what you want aesthetically, but they really should be at 90.
